Hard Case for NT2A?
pcm81
598
16
I have Rode NT2A mic, which i store together with the other audio gear in Pelican case. For now The mic is stored in a plastic bag, which is inside of the pouch that came with the mic. It then is placed into its own compartment in the pelican case (using pick and pluck foam).
I would like to get a hard case to store the mic in. I'd like to have as small of the case foot print as possible, with padded insides to "hug" the mic.
This hard case will be inside of the pelican case, but i don't want the mic to wooble inside of this case.
Can any one suggest such a case that would accommodate NT2A mic?
Kind of like the box from
Neumann U87 Ai Shockmount Set Z Microphone with Box
on amazon.
Thanks ahead.
