ThePresence
- Nov 19, 2001
- 27,727
- 16
- 81
I buy things from HT that I use really infrequently. If it were something that would see a fair amount of use, or infrequent heavy use I wouldn't do it.
how are their sawzalls? Home Depot ones are $100 but HF are < $50??? The amps are different - is that basically power? Will need to occasionally cut thin metal and typical wood.
Real lumberjacks use Axes.
A real man would punch a tree down.
One thing I find disappointing though is that back when I first learned to use a chainsaw (Doom I) I learned to attack with the tip. According to the HF manual, this can cause nasty kickback and is bad for the saw and the user. I think iD Software should have warned players of this safety issue.
