- Oct 3, 2010
- 953
- 3
- 91
We have some 4'x9' sheets of UHMW type of stuff, it is not your normal UHMW plastic. It has two thin sheets of metal on the inside along with some fiber material. This stuff is fairly heavy for 1/4" thick. I am not sure what you call this stuff, I will try to get a pic of it. It has a real slick surface making it easy to clean.
We plan on hanging these sheets on a cinder block wall and wanted to find out what would be the best method of attaching this stuff to the cinder block wall. I don't think those drive pin anchors will work because when they expand, I think they will crack the blocks. I am not too fond on using those blue tapcon screws, they seem to break easy.
I am not sure where would be a better place to ask this question since I don't know what the stuff is called.
