hanging shelf on concrete block wall.....
phatj
1,837
Wall made of concrete blocks grouted together. hanging shelf for big textbooks.... will screwing shelf into grout be stable?
meltdown75
37,548
7
I wouldn't. Get one of those concrete tapping drill bits and make a hole for your screw right in the block.
edit: choice handle :thumbsup:
nakedfrog
61,772
17,477
Hear hear. I wouldn't trust screws into grout holding up a heavy shelf.
vi edit
62,484
8,345
Hammerdrill + anchors + tapcons right into block = win.
Rastus
4,704
You don't need a hammerdrill for concrete blocks, they are soft enough to drill with a masonary bit and a regular drill.
spidey07
65,469
Yeah, but that's not nearly as fun as a hammerdrill.
0roo0roo
64,795
84
gonna need special concrete anchors and drillbits like above.
textbooks are heavy, grout is weak
bonkers325
13,076
if its a cinder block wall as u indicated, then there should be parts of the wall where it is filled with concrete every 4 feet (i.e. there will be a thin column of concrete inside the hollow part of the cinder block every 4'). find that strip of concrete and use that
phatj
1,837
thanks. just bought some masonry bits. i'm renting the place so I wasn't too keen on putting a whole in the cinder blocks (refilling holes w/ grout would be easy, otoh), but oh well!! who needs a security deposit, right?
AlienCraft
10,539
Bollocks, Just fill out the hole with some concrete / stucco patch. Do it all the time w/ the commercial units we service.
