- Jul 14, 2002
- 549
- 0
- 0
well I am about to get my first laptop and I was wondering what kind of things I should do to take care of it and extend its life..
will I be able to get a extended warranty plan after ive already ordered?Originally posted by: kayatai
for 1). the only real sure way is to purchase an extended warrenty. the battery will probably die just after 1 year, as that is all it is ever warrentied for.
for 2). check for dead pixels on the lcd. check to make sure all the software is up to date, including drivers and other patches provided by microsoft and the manufacturer. check to make sure you have reinstallation CD's (damned sony for not providing them!). check the battery life, make sure they didn't give you a bad battery off the bat. run PCmark or some other benchmarking software as a mini stress test and to check your numbers against comparable hardware, this is usually a pretty good indicator that most critical things arent configured poorly (ie hdd set for dma transfer etc).
how can I check the battery life?
i heard theres a battery guage on the dell 8500....
Originally posted by: vegetation
If you don't have a long warranty, extend your battery life by removing it from the unit whenever plugged in. All that heat and trickle charging takes its toll on premature battery failure.
