Question Handbrake, nvidia encoder not working, help?
Spec:
AMD Phenom II X4 960T with 6 cores activated, stock speed
ASUS M4A78T-E, latest BIOS
4GB RAM
128GB SSD
GeForce 760
Windows 10, latest version I think
Handbrake, latest version
I've used this graphics card in another system for most of my DVD ripping and I didn't have to do anything special to get it working then I'm pretty sure.
On this system though, encoding immediately fails. Here's the log:
Code:
HandBrake 1.4.2 (2021100300)
OS: Microsoft Windows NT 10.0.19044.0
CPU: AMD Processor model unknown
Ram: 4094 MB,
GPU Information:
  NVIDIA GeForce GTX 760 - 27.21.14.6677
Screen: 1920x1080
Temp Dir: C:\Users\Owner\AppData\Local\Temp\
Install Dir: C:\Program Files\HandBrake\
Data Dir: C:\Users\Owner\AppData\Roaming\HandBrake
# Starting Encode ...
[14:59:01] base preset: Fast 576p25 (Modified)
Remote Process started with Process ID: 7744 using port: 8037. Max Allowed Instances: 1
Worker: Starting HandBrake Engine ...
Worker: Starting Web Server on port 8037 ...
Worker: Disconnected worker monitoring enabled!
[14:59:02] Compile-time hardening features are enabled
[14:59:02] hb_init: starting libhb thread
[14:59:02] Starting work at: Sun Dec 05 14:59:02 2021
[14:59:02] 1 job(s) to process
[14:59:02] json job:
  "Audio": {
    "AudioList": [
        "Bitrate": 160,
        "DRC": 0,
        "Encoder": "av_aac",
        "Gain": 0,
        "Mixdown": 4,
        "NormalizeMixLevel": false,
        "Samplerate": 0,
        "Track": 0,
        "DitherMethod": 0
    "CopyMask": [
      "copy:aac",
      "copy:ac3",
      "copy:dtshd",
      "copy:dts",
      "copy:eac3",
      "copy:flac",
      "copy:mp3",
      "copy:truehd",
      "copy:mp2"
    "FallbackEncoder": "ac3"
  "Destination": {
    "ChapterList": [
        "Name": "Chapter 1"
        "Name": "Chapter 2"
        "Name": "Chapter 3"
        "Name": "Chapter 4"
        "Name": "Chapter 5"
        "Name": "Chapter 6"
        "Name": "Chapter 7"
        "Name": "Chapter 8"
        "Name": "Chapter 9"
        "Name": "Chapter 10"
        "Name": "Chapter 11"
        "Name": "Chapter 12"
        "Name": "Chapter 13"
        "Name": "Chapter 14"
        "Name": "Chapter 15"
        "Name": "Chapter 16"
    "ChapterMarkers": true,
    "AlignAVStart": false,
    "File": "C:\\Users\\Owner\\Videos\\Spirited test.mkv",
    "Mp4Options": {
      "IpodAtom": false,
      "Mp4Optimize": false
    "Mux": "av_mkv"
  "Filters": {
    "FilterList": [
        "ID": 13,
        "Settings": {
          "crop-bottom": "28",
          "crop-left": "28",
          "crop-right": "26",
          "crop-top": "28",
          "height": "520",
          "width": "666"
        "ID": 6,
        "Settings": {
          "mode": "2",
          "rate": "27000000/1080000"
  "PAR": {
    "Num": 64,
    "Den": 45
  "Metadata": {},
  "SequenceID": 0,
  "Source": {
    "Angle": 1,
    "Range": {
      "Type": "chapter",
      "Start": 1,
      "End": 16
    "Title": 1,
    "Path": "D:\\"
  "Subtitle": {
    "Search": {
      "Burn": false,
      "Default": false,
      "Enable": false,
      "Forced": false
    "SubtitleList": []
  "Video": {
    "Encoder": "nvenc_h264",
    "Level": "auto",
    "TwoPass": false,
    "Turbo": false,
    "ColorMatrixCode": 0,
    "Options": "",
    "Preset": "medium",
    "Profile": "auto",
    "Quality": 20,
    "QSV": {
      "Decode": false
[14:59:02] CPU: AMD Processor model unknown
[14:59:02]  - logical processor count: 6
[14:59:02] Intel Quick Sync Video support: no
[14:59:02] hb_scan: path=D:\, title_index=1
src/libbluray/disc/disc.c:437: error opening file BDMV\index.bdmv
src/libbluray/disc/disc.c:437: error opening file BDMV\BACKUP\index.bdmv
src/libbluray/bluray.c:2646: nav_get_title_list(D:\) failed
[14:59:02] bd: not a bd - trying as a stream/file instead
libdvdnav: vm: dvd_rlibdvdnav: Unable to open device file D:\.
ead_name failed
libdvdnav: DVD disk reports itself with Region mask 0x00bd0000. Regions: 02 07
libdvdread: Attempting to retrieve all CSS keys
libdvdread: This can take a _long_ time, please be patient
libdvdread: Get key for /VIDEO_TS/VIDEO_TS.VOB at 0x0000012d
libdvdread: Elapsed time 0
libdvdread: Get key for /VIDEO_TS/VTS_01_0.VOB at 0x000026d7
libdvdread: Get key for /VIDEO_TS/VTS_01_1.VOB at 0x0000aede
libdvdread: Found 1 VTS's
[14:59:03] scan: DVD has 2 title(s)
[14:59:03] scan: scanning title 1
[14:59:03] dvd: Skipping multi-angle cells 0-1
[14:59:03] dvd: Skipping multi-angle cells 2-3
[14:59:03] dvd: Skipping multi-angle cells 4-5
[14:59:03] dvd: Skipping multi-angle cells 6-7
[14:59:03] dvd: Skipping multi-angle cells 8-9
[14:59:03] dvd: Skipping multi-angle cells 10-11
[14:59:03] dvd: Skipping multi-angle cells 12-13
[14:59:03] dvd: Skipping multi-angle cells 14-15
[14:59:03] dvd: Skipping multi-angle cells 16-17
[14:59:03] dvd: Skipping multi-angle cells 18-19
[14:59:03] dvd: Skipping multi-angle cells 20-21
[14:59:03] dvd: Skipping multi-angle cells 22-23
[14:59:03] dvd: Skipping multi-angle cells 24-25
[14:59:03] dvd: Skipping multi-angle cells 26-27
[14:59:03] dvd: Skipping multi-angle cells 28-29
[14:59:03] dvd: Skipping multi-angle cells 30-31
[14:59:03] dvd: Skipping multi-angle cells 32-33
[14:59:03] scan: duration is 01:59:30 (7170040 ms)
[14:59:03] pgc_id: 1, pgn: 1: pgc: 00000220a252eae0
[14:59:03] scan: checking audio 1
[14:59:03] scan: id=0x80bd, lang=English (AC3), 3cc=eng ext=0
[14:59:03] scan: checking audio 2
[14:59:03] scan: id=0x81bd, lang=English (AC3), 3cc=eng ext=0
[14:59:03] scan: checking audio 3
[14:59:03] scan: id=0x82bd, lang=??? (AC3), 3cc=jpn ext=0
[14:59:03] scan: checking subtitle 1
[14:59:03] scan: id=0x20bd, lang=English (Wide Screen) [VOBSUB], 3cc=eng ext=0
[14:59:03] scan: id=0x21bd, lang=English (Letterbox) [VOBSUB], 3cc=eng ext=0
[14:59:03] scan: title 1 has 16 chapters
[14:59:03] scan: chap 1, 648200 ms
[14:59:03] scan: chap 2, 416440 ms
[14:59:03] scan: chap 3, 246880 ms
[14:59:03] scan: chap 4, 443760 ms
[14:59:03] scan: chap 5, 594040 ms
[14:59:03] scan: chap 6, 591000 ms
[14:59:03] scan: chap 7, 635000 ms
[14:59:03] scan: chap 8, 457960 ms
[14:59:03] scan: chap 9, 377480 ms
[14:59:03] scan: chap 10, 322440 ms
[14:59:03] scan: chap 11, 517520 ms
[14:59:03] scan: chap 12, 566720 ms
[14:59:03] scan: chap 13, 535360 ms
[14:59:03] scan: chap 14, 437880 ms
[14:59:03] scan: chap 15, 164320 ms
[14:59:03] scan: chap 16, 215040 ms
[14:59:03] scan: aspect = 16:9
[14:59:03] scan: decoding previews for title 1
li[14:59:03] dvd: Skipping multi-angle cells 32-33
[14:59:03] scan: title angle(s) 2
[14:59:04] scan: audio 0x80bd: ac3, rate=48000Hz, bitrate=192000 English (AC3) (2.0 ch) (192 kbps)
[14:59:04] scan: audio 0x82bd: ac3, rate=48000Hz, bitrate=448000 ??? (AC3) (5.1 ch) (448 kbps)
[14:59:04] scan: audio 0x81bd: ac3, rate=48000Hz, bitrate=448000 English (AC3) (5.1 ch) (448 kbps)
[14:59:05] scan: 10 previews, 720x576, 25.000 fps, autocrop = 28/28/28/26, aspect 16:9, PAR 64:45, color profile: 5-5-5
[14:59:05] libhb: scan thread found 1 valid title(s)
[14:59:05] Starting Task: Encoding Pass
[14:59:05] work: track 1, dithering not supported by codec
[14:59:05] job configuration:
[14:59:05]  * source
[14:59:05]    + D:\
[14:59:05]    + title 1, chapter(s) 1 to 16
[14:59:05]  * destination
[14:59:05]    + C:\Users\Owner\Videos\Spirited test.mkv
[14:59:05]    + container: Matroska (libavformat)
[14:59:05]      + chapter markers
[14:59:05]  * video track
[14:59:05]    + decoder: mpeg2video 8-bit (yuv420p)
[14:59:05]      + bitrate 200 kbps
[14:59:05]    + filters
[14:59:05]      + Framerate Shaper (mode=2:rate=27000000/1080000)
[14:59:05]        + frame rate: 25.000 fps -> peak rate limited to 25.000 fps
[14:59:05]      + Crop and Scale (width=666:height=520:crop-top=28:crop-bottom=28:crop-left=28:crop-right=26)
[14:59:05]        + source: 720 * 576, crop (28/28/28/26): 666 * 520, scale: 666 * 520
[14:59:05]    + Output geometry
[14:59:05]      + storage dimensions: 666 x 520
[14:59:05]      + pixel aspect ratio: 64 : 45
[14:59:05]      + display dimensions: 947 x 520
[14:59:05]    + encoder: H.264 (NVEnc)
[14:59:05]      + preset:  medium
[14:59:05]      + profile: auto
[14:59:05]      + level:   auto
[14:59:05]      + quality: 20.00 (CQ)
[14:59:05]      + color profile: 5-5-5
[14:59:05]  * audio track 1
[14:59:05]    + decoder: English (AC3) (2.0 ch) (192 kbps) (track 1, id 0x80bd)
[14:59:05]      + bitrate: 192 kbps, samplerate: 48000 Hz
[14:59:05]    + mixdown: Stereo
[14:59:05]    + encoder: AAC (libavcodec)
[14:59:05]      + bitrate: 160 kbps, samplerate: 48000 Hz
libdvdnav: vm: dvd_read_name libdvdnav: Unable to open device file D:\.
failed
[14:59:06] dvd: Skipping multi-angle cells 0-1
[14:59:06] dvd: Skipping multi-angle cells 2-3
[14:59:06] dvd: Skipping multi-angle cells 4-5
[14:59:06] dvd: Skipping multi-angle cells 6-7
[14:59:06] dvd: Skipping multi-angle cells 8-9
[14:59:06] dvd: Skipping multi-angle cells 10-11
[14:59:06] dvd: Skipping multi-angle cells 12-13
[14:59:06] dvd: Skipping multi-angle cells 14-15
[14:59:06] dvd: Skipping multi-angle cells 16-17
[14:59:06] dvd: Skipping multi-angle cells 18-19
[14:59:06] dvd: Skipping multi-angle cells 20-21
[14:59:06] dvd: Skipping multi-angle cells 22-23
[14:59:06] dvd: Skipping multi-angle cells 24-25
[14:59:06] dvd: Skipping multi-angle cells 26-27
[14:59:06] dvd: Skipping multi-angle cells 28-29
[14:59:06] dvd: Skipping multi-angle cells 30-31
[14:59:06] dvd: Skipping multi-angle cells 32-33
li[14:59:06] dvd: Skipping multi-angle cells 32-33
[14:59:06] sync: expecting 179251 video frames
[14:59:06] encavcodecInit: H.264 (Nvidia NVENC)
[14:59:06] encavcodec: encoding at rc=vbr, multipass=fullres, 20.00
[14:59:06] encavcodec: encoding with stored aspect 64/45
[h264_nvenc @ 00000220a28aeb00] Lossless encoding not supported
[h264_nvenc @ 00000220a28aeb00] No capable devices found
[14:59:06] encavcodecInit: avcodec_open failed
Failure to initialise thread 'FFMPEG encoder (libavcodec)'
[14:59:06] vfr: 0 frames output, 0 dropped and 0 duped for CFR/PFR
[14:59:06] vfr: lost time: 0 (0 frames)
[14:59:06] vfr: gained time: 0 (0 frames) (0 not accounted for)
[14:59:06] ac3-decoder done: 0 frames, 0 decoder errors
[14:59:06] mpeg2video-decoder done: 0 frames, 0 decoder errors
[14:59:06] sync: got 0 frames, 179251 expected
[aac @ 00000220a228e500] Ignoring attempt to flush encoder that doesn't support it
[aac @ 00000220a228e500] Qavg: nan
[14:59:06] Finished work at: Sun Dec 05 14:59:06 2021
[14:59:06] libhb: work result = 3
# Job Failed to Initialise. Check log and input settings (3)
It ripped the same DVD in software fine, and I'm attempting to do H264 encoding with nvenc which I know has worked with this card and H265 NVENC doesn't. The only relevant differences I can think of between this PC and the previous PC this card was an older version of Handbrake was on the other one and likely a different nvidia driver, but I tried the last of the 46x driver versions as well as the latest version, same problem. I could try an even older driver in case nvidia killed nvenc support for the 760?
The only other thing I can think of trying is trawling through the BIOS to check for some weird AMD hybrid on-board+dedicated graphics solution that is somehow putting a spanner in the works.
Possible solutions below:
Had to roll all the way back to the 411.70 drivers to fix it.
Actually I forgot to disable VT-D.
So I followed your recommandations, disabled VT-D and used the 442.74 driver: It now works on mediacoder but not in kdenlive.
Maybe there's an AMD specific VT-D option in your BIOS?
That link says that VT-D needs to be turned off and network needs to be disconnected when nVidia's driver installation is trying to detect the hardware otherwise the installation will get corrupted. What the heck?! nVidia's driver quality must have tanked hard in recent times for this state of affairs to be the norm now.
Sorry for not responding sooner, things have been a bit chaotic and today's the first time I've felt I had time to have another look at the problem.
I tried various driver versions though the nvidia site only lists something like 451 as their oldest driver for this card. I felt that this was barking up the wrong tree because I've never had driver issues with this card previously and it was only at the start of this year that I had been using Handbrake with this card successfully.
I also tried disabling virtualisation, no dice there.
Lately the thought occurred to me that I had been using Handbrake 1.3.2 previously and the latest version is something like 1.4.2, so this morning I uninstalled the new version and installed 1.3.2 (luckily still on the Handbrake site, I'm a bit surprised I didn't still have the install file locally as that is how I usually do things), and 1.3.2 is working just fine with nvidia encoding!
I'll probably install the latest nvidia driver after this test rip finishes.
