I rarely put my desktop into sleep mode but I did the other day and when I went to go wake it up the computer was running, fans on, monitor in standby. No matter what I did, the monitor stayed in standby. Even the reset and power buttons wouldn't reset or power it down, including holding power for 10 seconds. I had to kill it with the switch on the PSU. When I powered it back up I noticed it said I had 8192 MB of memory which is not correct since I have 16,384 MB normally and have not ever changed my RAM configuration. I have 4x4GB installed. Looking in the UEFI it shows 8192 MB installed but there is a section where I can select each DIMM and all show XMP profiles and values. In Windows running CPU-Z I can see all four DIMMs yet Windows only see 8GB. I cleared the CMOS and even re-flashed the UEFI/BIOS and it didn't change anything
I spent some time last night removing the sticks of RAM and installing them one at a time and saw some really odd things. When I populated the first DIMM (A1) I got a RAM configuration error, possibly because it needs two DIMMs for dual channel. Then I installed the second stick into B1 (A1+B1 for 2 sticks is proper according to manual) and it showed 8192 MB in the DIMMs I was using, good. Then I put the other two sticks in A2 and B2 (A1 & B1 still installed) and when I booted it showed 8192 MB but only the sticks in A2 and B2. I noticed after several boots it seems to choose either the A1/B1 pair or A2/B2 pair but never all four like it used to, and it seems fairly random.
Is my motherboard smoked or does it seem like there is a problem with one or more memory sticks?
System specs:
ASRock Z77 OC Formula (2.30 firmware)
G.Skill F3-14900CL9-4GBZL (4GB x 4)
Intel i5 3570K (was running @ 4.6 GHz but now at stock for troubleshooting)
Windows 10 Home 64-bit
I definitely have some more troubleshooting to do but I was hoping to get some feedback and experience from everyone on this problem.
I was thinking of upgrading to a 6700K but had recently convinced myself I should save some money and hold off. Now thinking I may have to go back to the upgrade plan.
TL;DR
UEFI and Windows show 8GB of 16 GB installed. All sticks can be seen in UEFI and CPU-Z but only half actually usable. Happened after powered off while locked up in sleep.
Any help/suggestions are welcome. Thanks!
System specs:
TL;DR
