Hahaha.. I didnt think it was possible....
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Somehow i broke my freakin floppy drive... It wont even read any disk's now... Any way to fix one? I know their only like $9 but thats dinner right there..
Every disk i put it it says it needs to be formatted, when i try to format, it says disk is write protected (which its not). Its makin some pretty funky noises too, anyone know?
if you have a disk cleaner you can try using that.. but if the heads are out of alignment then you got replace it.. its hard to get it back into alighment.
Its 9bucks.. spend it.. its not expensive.. and you can still eat.. just get some ramen before you buy that floppy.
