HAF 922 with CM USB 3.0 front panel
Not sure if it would work or not as it looks kinda like specific to the case style, etc.
The Asrock one is much nicer as it is also a SSD mount. Fits in standard 3.5" inch bay or 5.25" bay with cases adapter....Using it in my HAF 932
Might be worth a call to see how much and if available for real. Found this post in another forum.
If you want to buy USB3.0 front panel, please kindly refer to below information to contact our America branch for assistance.
ASRock America, Inc.
13848 Magnolia Ave, Chino, CA91710
U.S.A.
Phone: +1-909-590-8308
Fax: +1-909-590-1026
e-mail: sales@asrockamerica.com
Thanks for your support!
Have a nice day
ASRock TSD
Emily
Ah, cool. Thanks much!
EDIT: Received a response back from CM that either of those brackets would work with the 922. Of course, the cost of 922 + a USB 3.0 panel is within a few bucks of a 400R + 2 fans for top exhaust, so I'm kind of back to square 1.
Even with the added expense of the 3.0 front panel, the HAF922 is a pretty nice case to build in... I love mine. Those big 200mm fans move some air...
Yeah, I'm still torn between the two...I like that I probably wouldn't need more fans with the HAF and I wouldn't really need the USB 3.0 adapter, just a convenience thing. Although I've also started thinking about just jumping up to a 600T depending on how the tax returns come out. :sneaky:
Yeah, the 200mm fans in the HAF series of cases are excellent (HAF 912 Plus here). You can set them running at lower speeds and they still pump enough air.
I just put a Lamptron 4-fan controller in my 922, running them at 50% now... hardly know it's over there. :thumbsup::thumbsup::thumbsup:
