I have a old Asus A7N8X Deluxe that I use for file sharing. I have 2x 250gb SATA drives in RAID 1. I had to update the BIOS because I got a known issue with the RAID controller. I did take out the SATA drives and check them on my main system but after the BIOS update I deleted teh Raid 1 array since I couldn't do anythingelse with it, I then created the array by telling the drives to copy the data of 1 of them to the other. It took a while and at 3:25am while letting the dog out I came in here to check to see if it was done. It now showed both drives as current but once I booted into XP the system did not show the drives except under Disk Management, shows up as uninitialized disks. So I just took the drives out again and put them in my main system and same thing they have no drive letter and don't show any DATA!!!!!!!!!!!!!!!!!!!!!!!!!!!
I need to use something to pull up the data on these, I did not format I just recreated the array in BIOS since I had no other option and set for manual creation to copy one disks data onto the other and after that noda, blank drives with no way to access anything in windows.
If you can help me I would be SOOO Grateful!!! Thanks for your time.
-eno
-eno
