tylerdustin2008
Ok i had a problem setting up my second lcd.
I wanted to be able to make apps pop up in one and be able to drag to the other lcd.
I also wanted the whole taskbar running across the bottom of both lcd's.
And of course the game will only run in one of the lcd's.
The fix.
Click on the desktop clicked on NVIDIA display and clicked on my lcd. Go to nView display settings and select DUALVIEW under nView display mode. And select which monitor you wish to be your primary.
You will want to download Ultramon. Install it then restart your comp. Then once windows is running again open Ultramon, if not already running. Right click on it and select the options you wish to have. And dont worry about it if it looks confusing, it is not. It is only confusing if you are to double click on it.
The fix.
