mosslack
Originally posted by: Kaido
FYI - Windows 7 creates 2 partitions, the bootloader partition ("System Reserved") and then the Windows partition (whatever you name it, or "Untitled"). When using Chameleon as a bootloader, you need to select the "System Reserved" partition in order to boot up Windows 7. If you select the other partition, it will just give you a boot manager failure notice.
Also, you will see both of these partitions on your desktop. You can access NTFS drives natively (read) in OS X, but you cannot write to them (copy files to the NTFS-formatted drive) without a driver. For that, you need MacFUSE and NTFS-3G (both free). The latest NTFS-3G installer for Mac OS X includes MacFUSE, which you can download here:
http://macntfs-3g.blogspot.com/
Just curious, where did you read this? I don't recall this being the case when I installed the beta version. It was just like Vista IIRC. Unless they made changes, which is very possible.
