Hackintosh 10.5.5 Retail Rig - Starting at $305
Page 180 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
alfa147x
29,305
104
Not that hard, I had my UD3P setup like that for awhile which is why I got interested in multiple cards/monitors. Just make sure you have your DSDT setup properly for it, that is the biggest thing as the graphics enabler won't do it on it's own.
The biggest problem I had in setting up 3 cards was getting the slot info into the DSDT, finally had a guy over on another forum who set mine up for me. I'm not the best when it comes to DSDT editing, but I can do the simple stuff.
Another question. If I get another 460 gtx and install the SLI bridge would that mess up the hackintosh portion of my build? I'm asking because I would like to run 3 monitors in OS X but just two monitor while the cards are SLI'd under windows (for games)
Thanks so much for the help
mosslack
902
hq-a.weebly.com
Sounds like a neat idea, but having never done that I can't really tell you. Multi gfx cards knowledge is scarce in the forums, but there are a few gurus out there who can help. kdawg on Insanely was the one who gave me a DSDT solution for my MSI system initially.
There is also a forum which specializes in such questions but the name escapes me at the moment. Perhaps someone else knows the name.
alfa147x
29,305
104
Just found a in.plist for dual GTX460
Now I need to figure out how to use it
alfa147x
29,305
104
So before my 2nd 460 arrives. I need to get my current card running without having graphicsenabler set to yes.
Right?
mosslack
902
hq-a.weebly.com
Right?
That is the way I did it on mine, got the system all set up running 10.6.x and then after I got my DSDT worked out I put the other gfx cards in and I was good to go up through 10.7.1. But 10.7.2 created another wrinkle, prob b/c Apple changed gfx drivers. A small change was needed to my DSDT and now everything works as it should.
Biggest thing needed for 2 gfx cards is the slot order IIRC. The primary is the one closest to the CPU and they need to be identified in the DSDT.
EDIT: I've put together a couple of files to show what mine looks like and you can download it here if you want:
http://dl.dropbox.com/u/47221269/Archive.zip
It basically shows the gfx sections from my DSDT for the first 2 cards in my system along with changes I had to make etc. Also contains a capture from the display section of my system info. HTH
alfa147x
29,305
104
Oh wow thanks! I'll have to build a DSDT file for my current card first. I just checked the one from KakeWalk and it doesnt have any GPU information.
alfa147x
29,305
104
alfa147x
29,305
104
I was dragging gfxutil to terminal to get it's path then running it like this:
/Users/Twesh/Desktop/GFX/gfxutil -i xml -o hex ./in.plist ./out.hex
That was the problem. Once I did cd /Users/Twesh/Desktop/GFX/ then did
./gfxutil -i xml -o hex ./in.plist ./out.hex
It worked fine.
Time to install the 2nd card :D Wish me luck!
alfa147x
29,305
104
excuse the wire mess. Still hooking things up :D
Got both cards working on the first boot. Edited the org.chameleon.Boot.plist installed the CUDA drivers and hooked up the 2nd card. Rebooted. Everything worked :D This was a lot easier than I was expecting. Now time to reboot with the SLI cable hooked up.
mosslack
902
hq-a.weebly.com
Did you mod the DSDT?
Kaido
Feb 14, 2004
48,688
5,443
Edited the org.chameleon.Boot.plist didn't touch the DSDT
is their a down side to this route?
QE is running on the 2nd card too.
Boots with SLI cable installed too
Whoohoo, I want pics!
And a guide :awe:
Kaido
Feb 14, 2004
48,688
5,443
Posted a quick review of the Angelbird Wings card:
http://www.appleknacks.com/archives/309
As a boot drive, I got 1071 MB/s read. As a data drive, I got 1471 MB/s read. Ridiculous. Currently on my i7 rig (8-cores with Hyperthreading & 24 gigs of RAM). Hackintosh FTW :awe:
mosslack
902
hq-a.weebly.com
So you are just using graphics enabler set to yes? You lucky dog. Of course I did have one more card so perhaps that may be why mine required the DSDT mods. If it does stop working on a future OS update, you may want to go with the mods as they can only help.
alfa147x
29,305
104
graphics enabler is set to no. Hopefully This will work :D
alfa147x
29,305
104
You have QE/CI and full resolutions?
Yes and Yes
It's pretty much like editing the DTSD directly but not really.
Code:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
	<key>PciRoot(0x1)/Pci(0x1,0x0)/Pci(0x0,0x0)</key>
	<dict>
		<key>@0,AAPL,boot-display</key>
		<string></string>
		<key>@0,can-hot-plug</key>
		<string></string>
		<key>@0,compatible</key>
		<string>NVDA,NVMac</string>
		<key>@0,connector-type</key>
		<string>AAAABA==</string>
		<key>@0,device_type</key>
		<string>display</string>
		<key>@0,display-connect-flags</key>
		<string>AAAAAA==</string>
		<key>@0,name</key>
		<string>NVDA,Display-A</string>
		<key>@1,AAPL,boot-display</key>
		<string></string>
		<key>@1,can-hot-plug</key>
		<string></string>
		<key>@1,compatible</key>
		<key>@1,connector-type</key>
		<string>AAABA==</string>
		<key>@1,device_type</key>
		<key>@1,display-connect-flags</key>
		<key>@1,name</key>
		<string>NVDA,Display-B</string>
		<key>AAPL,aux-power-connected</key>
		<string>0x00000001</string>
		<key>AAPL,backlight-control</key>
		<string>0x00000000</string>
		<key>AAPL,gart-width</key>
		<integer>64</integer>
		<key>AAPL00,blackscreen-preferences</key>
		<key>AAPL01,blackscreen-preferences</key>
		<key>IONVRAMProperty</key>
		<true/>
		<key>NVCAP</key>
		<data>
		BAAAAAAAAwAcAAAAAAAACgAAAAA=
		</data>
		<key>NVDA,Features</key>
		<string>0x108006ff</string>
		<key>NVPM</key>
		<data>
		AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
		</data>
		<key>VRAM,totalsize</key>
		<string>0x40000000</string>
		<key>device_type</key>
		<string>NVDA,Parent</string>
		<key>model</key>
		<string>GeForce GTX 460</string>
		<key>rm_board_number</key>
		<data>
		AAAAAA==
		</data>
		<key>rm_multiboard_capable</key>
		<data>
		AQAAAA==
		</data>
		<key>rom-revision</key>
		<string>70.04.1B.00.70</string>
		<key>subsystem-id</key>
		<string>0x00001080</string>
	</dict>
	<key>PciRoot(0x1)/Pci(0x1,0x1)/Pci(0x0,0x0)</key>
	<dict>
		<string></string>
		<string></string>
		<key>@0,name</key>
		<string></string>
		<string></string>
		<key>@1,name</key>
		<true/>
		<key>NVCAP</key>
		<data>
		</data>
		<key>NVPM</key>
		<data>
		</data>
		<key>built-in</key>
		<string>AA==</string>
		<string>NVDA,Child</string>
		<key>model</key>
		<data>
		AAAAAA==
		</data>
		<data>
		AQAAAA==
		</data>
	</dict>
</dict>
</plist>
That's the file I converted to Hex form then inserted in to the org.chameleon.Boot.plist
Very similar to your route
Status
