scootermaster
- Nov 29, 2005
- 2,411
- 0
- 0
Just an FYI: ATI remote wonders are supported in OSX and seem to work pretty well. Strangely, not default support for front row, but it's not hard to add.
Originally posted by: mosslack
Did as you suggested and this time it worked. Why does copying it to the apps folde make a difference?
Just a message from Doug...
Originally posted by: swilso
Originally posted by: Kaido
Nope, I run 2 VM's 24/7 and it's rock-solid. Have you run memtest? Are you overclocking? Do you have the latest updates for both applications? What are your full hardware specs?
I am pretty sure it is IDE related. I am running overclocked on an e7300 although it is pretty solid at 3ghz. I got an IDE error in parallels once before.
I have since disconnected my IDE HDD with only the IDE DVD drive (which doesnt work in leopard anyway) connected and vmware hasn't skipped a beat now.
Does that Dell 1505 you mentioned kaido run at full bandwidth ? has anyone tried it with all new updates and have it running at full bandwidth? My WL-138G V2 was spose to have 100% compatibility as reported by most users although the speeds are shocking. I might buy a long arse ethernet cable even and run it to my PC.
Final Draft - Upgrade Guide:
This will update your USB boot stick installation as well as your USB-to-HDD method posted earlier. If you're using the USB boot stick method, you won't have an Extensions.mkext file in step #7, but you may have an Extra/Extras/Extra Content folder in there, and you can delete that instead.
http://www.mediafire.com/?shar...a335cae1508bd5622028d6
1. Unzip to desktop
2. Inside the "DS3L-Kit" folder, open the "Software" folder
3. Open the "Audio" folder, drag the ALC888.codec.txt onto the frog icon and install
4. Open the "DSDT" folder, copy "dsdt.aml" to the root of your boot drive (with Library, System, Users, etc.) and install Chameleon to the boot drive
5. Open the "Kext" folder, open Kext Helper and install all of the kext files
6. Open the "Tools" folder, install EFIStudio (Video Card + Ethernet) and OSX86Tools (boot resolution + boot timeout) like usual
7. Inside the bot drive, open "Extras" and delete the Extensions.mkext file inside
8. Reboot
Added 10.5.6 compatibility (thanks to DSDT) and switched back to the Taruga audio method (no audio "pop" on analog output). Once this is tested on the Rev1 P35 as well as the EP35, and we get enough people testing IDE (including users with 4GB RAM to check for that bug), this will be named the final release. Then I'll wrap up the guide, record the tutorial video, and release it!![]()
Hey is there anyway to do this install from the harddrive. I am having trouble with my leopard retail disk, well it could also be my dvd drive. As it works in mac with ahci but not in windows. It does install kalyway fine though.
Could I use a kalyway install on 320gig HD. And install from the same said 320GB HD? I am getting as far as the install screen. The grey one with the apple in the middle along with a 0/ through the apple. Meaning it locked up. I have checked and double checked all the bios settings.
Originally posted by: mohkahn
@Mosslack:
AppleScript Error
/bin/sh: /Volumes/Local: No such file or directory (127)
I was having the same problem and my system won't even boot once I ignore this step and restart pc.
Please use Kaido's advise and install the osx86 to application folder and what worked for me amazingly was that I put the 5 with "5" quotes.. So try that, who knows.![]()
Now to question: how do I turn off the system keep asking me to authenticate everytime I do a minor
copy and paste operation? Like If i create a folder and want to move some dmg files into it, system will require me to type in password?
is this a bug or can I change this behaviour somewhere? thanks for the input.
Originally posted by: QurazyQuisp
So what is/was the point in moving away from the use of the memory stick? I understand that it's taking up a usb port, however, it seems to keep the OS & bootloader separate for a more "vanilla" install.
Can I use the memory stick method?
So, I'm emailing you from my $350 Mac. No, not my woefully outdated
Powerbook G4 (which, ironically, isn't worth much more than that --
there goes the $2200 I spent on it). No, I'm writing from my brand
spankin' new hackintosh.
So, yes, I bought PC hardware and put Leopard on it. And it rules. The
thing flies. And it's quiet. And no, it's not in a pretty aluminum
box, but then again, it does cost a quarter of an iMac and is faster.
Also, I want the info on that Hackintosh thingy too.
If you guys are at all interested, I can send you my recipe for Hackaroni and cheese. I'll give you a hint: you chop up spaghetti into small bits and then add some velveeta. It doesn't have the nice little holes for more cheese, but it gets the job done.
[/quote]If you guys are at all interested, I can send you my recipe for Hackaroni and cheese. I'll give you a hint: you chop up spaghetti into small bits and then add some velveeta. It doesn't have the nice little holes for more cheese, but it gets the job done.
I think the admin issue with Kext Helper etc. may be due to 10.5.5 disabling admin privledges or something after installing. For those of you with that error, try re-installing completely from scratch, then install the SOFTWARE portion, THEN install the 10.5.5 update. For some reason this only happens to a few people, but this may resolve it. Please report back with your results!
Okay, I did a complete re-install and used the following procedure (ref quickie instructions)
Steps 1-7 as they are
Next I installed all the Kext using Kext Helper, worked fine.
Installed 10.5.5 combo update (No reboot yet)
Installed Audio
Installed DSDT.AML for my board
Installed Chameleon
Used EFI Studio to install Video and Ethernet
Tried to use OSx86 Tools to edit the boot.plist file, but got the following error
AppleScript Error
Rebooted. Everything seems to work okay, tried the OSx86 Tools again, but got the same error. Did the minor updates and things seem to work just fine. Will have to edit the boot.plist file by hand I guess.
BTW I installed this on the SATA drive. Figured I could always use the backup ATA drive to restore it from is things went horribly wrong. 8^)
1. Try installing ALL the Software before 10.5.5
2. Try copying OSx86Tools to your Apps folder, THEN running it
Did as requested and on an ATA drive. Everything seemed to work, but when I rebooted after installing the 10.5.5 update I have no sound at all. I just did the audio patch again and rebooted, now I have sound. It seems the way I did it first worked better, after initial Leopard install do the kexts, then the 10.5.5 update, then the rest of the software portion and reboot. JMHO
Yup, point updates overwrite the sound. Luckily we have a drag-and-drop installer so it's real easy. I'm on the fence about how to approach the software installation issue. Several notes:
1. Installing a point update seems to disable admin access to system areas (like Extensions) until after rebooting
2. Point Updates break audio and require Taruga re-installation
3. Some Video Cards do not work until after 10.5.0 (so unless you have a 10.5.4 disc, you can't install the video until after updating or else it won't boot)
So...it seems like the overall best method is to do the following:
1. Install Kexts, Strings, DSDT, Chameleon
2. Install 10.5.5
3. Install Taruga for audio
4. Reboot
I'm just not sure if #3 will work until AFTER 10.5.5 has rebooted, so I'll add that to my test list. If not, it will be like this:
2. Install 10.5.5
3. Reboot
4. Install Taruga for audio
5. Reboot
I have a 2nd tab in the 1-Click Installer App for "Updates" that simply installs Taruga, which is required after installing each point update anyway, so I think the second method above is the best way to go (unless the first way actually works).
Sometimes this hobby makes me want to be a Mac Pro...lol.
I didn't know about the video problem as mine works fine with 10.5.0. In that case the slight inconvenience of patching the audio after the update would seem the best choice. I look forward to the 1-Chick Installer App, sounds like my kind of app! Keep up the great work.
Originally posted by: albinobumblebee
I've been looking for used mac pro to run FCS2, AE, and using it as a work station, however i'd rather save 3grand so i began to investigate hackintoshs and ran across a guy online who was making "Dual Boot INTEL MAC PRO Clone/Dual Core 4.2 Ghz/4Gb RAM"
I was curious if you knew whether the 4.2 Ghz @ 1600 Mhz FSB would work and if so would that be faster then you suggested processor? These were the hardware specs he said the machines he was building had.
HARDWARE SPECS:
Intel Dual Core Processor - 4.2 Ghz @ 1600 Mhz FSB ( Upgradeable to Intel Quad Core Extreme )
4 GB DDR3 1600 Mhz (PC3 12800) Dual Channel RAM - G.Skill ( Upgradeable to 8GB )
EVGA Nvidia GeForce 9800GT 512 MB 256-bit GDDR3 PCI Express 2.0 Video Card ( Upgradeable to GeForce GTX 280 1GB 512-bit GDDR3 )
Seagate 750 GB 7200 RPM SATA 3.0Gb/s Hard Drive ( Upgradeable to 5 x 1TB 7200 RPM SATA 3.0Gb/s Hard Drives )
LG SATA 22x DL DVD Burner with LightScribe
Thanks
Noob
To everyone with IDE problems:
http://darwin-ata.googlecode.com/files/JMicronATA.kext.zip
Remove the legacyjmicron.kext, delete extensions.mkext, and try this one. See if it works for you. Snagged from this thread:
http://forum.insanelymac.com/index.php?showtopic=127611
Dumb question: How do we remove the legacy.kext?
Kaido, you wrote "Sounds like a bug. That shouldn't happen. I'm testing various installation methods on my machine this evening; might be worthwhile to re-install with Software THEN 10.5.5.""
Do you mean the fact that I have to put 5 within quotes is a bug?
or you mean the fact that while doing minor functions (like move files, folder from one place to another or copy and paste operations) the system asks me to authenticate or prompts me to put password is a bug? If not, then how can I stop system giving me this nag, it's worse than vista's UAC.
If yes, then, I can wait and redo this thing after your final guide, ETA thanksgiving?
by the way happy thanksgiving in advance.
What video card do you have again?
