Originally posted by: mohkahn
Man.... I just couldn't wait for the final guide (like always.
} so I finally took the plunge and burned the boot132cd.iso. Then I partitioned my kalyway hackintosh disk into 2 and put leopardretail.dmg on the 2nd partition, which was about 11gb, but finally was showing as 7+gb.. (Here I must mention though that I could not rename my old main hackintosh drive, which had a running kalyway system about 130+ or 140gb, as it was grayed out)
anyway put in the bootcd, and when I got to first hd 80 and second hd81.. I kept putting 9f or 9e, mine was showing 9e. it won't go any further, then i just put 80 or 81... and i don't know which one worked, but screen changed to ask me, which partition i wanted to use. I clicked to leopard, the 11gb partition on which I had put the retail image and voila installer is right now " Installing Mac OSX on the volume "Leo" and 3 minutes remaining..
here I must mention and ask: as per instructions I had taken out boot132cd and had put in my retail image DUAL LAYER dvd, which is burned as an iso.. but the computer just spit it out for some reason? should it have been iso? or should I burn another dual layer dvd as a leopardretail.dmg, incase in future I don't want to install from harddisk and just wish to straight install from retail dvd. as I don't mind the little bit extra time.
this could not have been easier.. I did not choose to uncheck any programs at the time of installation, so everything is going on the system now. wish me luck kaido and thanks a tonne and might be back if I stumble on any problems.. must share the happy news immediately..
and man, don't you ever sleep, ur bulb says u are online... it's like 4am in US? right?...
