Hackintosh 10.5.5 Retail Rig - Starting at $305
Page 113 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
mosslack
902
hq-a.weebly.com
EDIT 2: Found a place that has a X-Fi card fix. VoodooHDA link from here.
Now back to finding a drive solution. Even if I get another 300 VRaptor, I still have no place to put it in my machine without probably doing some customizing - thank god I got a dremmel kit. EDITING for an actual 4th time. Say I do get a new drive. How do I format it for a Mac OS
Partitioning and formatting can be done from the Leopard install DVD. As soon as it boots to the install routine simply choose Disk Utility from the Utilities menu. This is all covered in Kaido's guide, you did download it didn't you?
Do you mean at the beginning of the thread!? I seen some of the d/l kits. My board is a UD3R v1.1 F9 bios. I know they are very similar boards but couldn't something go wrong with it and the UD3P kit?
Also. I have a 300 VRaptor on the way. I'll be figuring out where to mount it in the meantime. In section - X. Preparation, I read That I need a constant USB drive installed on the machine and the Install has to go from an ISO file not straight from the external USB DVD drive I have: that I am familiar with in a Windows installation procedure. Are those two methods the only way or are there others? I don't understand.
so it doesn't get lost i just wanted to quote this... did some editing, thanks sorry
The first line of this thread is the most important one:
This is an OLD OLD OLD thread!
So many things have changed since then that none of the original thread really applies any more and as such you can ignore it and just use the info which applies to your board. In your case I would suggest the UD3P kit as it is very close to your UD3R, but still no guarantee it will work. If you click on the UD3P link it will better explain how to do this. HTH
Kaido
Feb 14, 2004
48,732
5,470
Originally posted by: mdrace
It seems like their is a passion to develop these drivers for this community. It's just a matter of time for the developers to do their magic. Who knows, you may be re-writing those guides with a 64 bit section as our christmas present. It will be an exciting time when 10.6 is released.
Already have installer & guides ready for Snow, just waiting on the devs & official release ;)
Nov 26, 2005
15,166
390
Looks like I'm down to figuring out what to do about a sound card and a NIC card, i'll figure out the SCSI card later. My onboard NIC went to hell but I've been using Bigfoots Killer NIC and then my sound card isn't compatible (Xtreme Gamer.)
EDIT: Funny, I checked Adaptec first and this is what I found. Looks like for the most part Adaptec SCSI cards made for a PC can NOT work with a Mac :(
Sound:
http://www.newegg.com/Product/...x?Item=N82E16812186035
previous questions now irrelevant.
So you have the sound card working in OS X now? That's pretty cool, never thought the X-Fi would ever work with OS X. Did you just install the Voodoo HDA kext? Any idea of digital out works?
No. All I have done is bought OS X 10.5.6 & Final Cut Express. I have an extra 1GB Attache flash drive ready & a new HD coming in cause my Adaptec card will not likely be supported for MAC. All I've done is get my Flash drive ready and figured out a spot to put my new 300 V raptor in. I'm actually going to screw in the HD cage right now.
...I found that while researching...
mosslack
902
hq-a.weebly.com
Sound:
If you haven't checked Kaido's Twitter, here is the newly posted thread on Insanely:
http://www.insanelymac.com/for...x.php?showtopic=174663
Be sure to give this a look see before you go too far. HTH
Nov 26, 2005
15,166
390
Can we pre-download 10.5.7? I bought 10.5.6 and have an ATI Sapphire 4870 vanilla 512mb card...
EDIT: and what speed does the fan run at in a Hackintosh?
Kaido
Feb 14, 2004
48,732
5,470
Originally posted by: renderingrocks
Will 10.5.8 require different video card drivers? Look at this advisory from nvidia. http://www.macworld.com/articl...64/2009/07/nvidia.html
Nobody knows what's in 10.5.8 so far, but I can tell you 2 things:
1. Both of the cards mentioned in the article already require special drivers (not the standard Nvidia EFI string we're using now), so updating them for 10.5.8 won't be anything new
2. Snow Leopard works just peachy with existing drivers (Leopard's EFI string method = OK)
Kaido
Feb 14, 2004
48,732
5,470
Originally posted by: f00b4r
Want a beta tester for the snow kitty guide? i have ud3p and the d3sl boards
There's still a ways to go, but as soon as the devs patch a few more things up I'll hit you back, thanks! :)
Kaido
Feb 14, 2004
48,732
5,470
Here's the 10.5.7 Combo Update, 729 megs:
http://support.apple.com/downl..._X_10_5_7_Combo_Update
Saves a LOT of time vs. downloading it from Apple Software Update!
Hackintosh doesn't support fan speed controls; just let the motherboard manage it. You can either setup a smartfan for auto-regulation in the BIOS, or you can install some manual rotary knobs for controlling the fan speeds yourself.
Kaido
Feb 14, 2004
48,732
5,470
Originally posted by: mosslackIf you haven't checked Kaido's Twitter, here is the newly posted thread on Insanely:
Finalizing the ES2L & DS3L guides this week as well, as soon as those are up, the new 10.5.7 Anandtech thread goes up and we can deep-six this beast of a thread here :D
Nov 26, 2005
15,166
390
Gratzi!
Shwymie
13
Hackintosh virgin here...
I just wanted to say thank you to everyone for their suggestions and advice (and especially Kaido for his great guides and tools!). Based on everything I have read from this thread I am now jumping into the waters of HTPC, hackintosh style! I have the following on order and hopefully, once all the parts get here, I will be able to follow the latest and greatest of Kaido's offerings! I'll let you know how everything goes!
Here's my list (with where bought and price; some prices include rebates/discounts). I'm a little bit worried about the video card (ASUS EN8400GS SILENT/HTP/512M), but the GeForce 8400 512 MB does appear on the list that Kaido linked to for the DS3L mtb (http://www.scribd.com/doc/7618558/Video-Cards).
GIGABYTE GA-G31M-ES2L (from mwave; $111 for mtb and cpu combo)
PENTIUM E5200 (from mwave; see above)
ASUS EN8400GS SILENT/HTP/512M GeForce 8400 (from zipzoomfly; $28.99)
SAMSUNG Spinpoint 1TB SATA Hard Drive (zipzoomfly; $73.99)
CORSAIR 4GB PC2-6400 (DDR2-800) Dual Channel (zipzoomfly; $29.99)
Antec New Solution NSK2480 HTPC case with 380W PSU (newegg; $117.45)
LINKSYS USB 2.0 Wireless Adapter with Dual-Band (newegg; $34.99)
Sony Optiarc 24X Dual Layer DVD+/-RW SATA Drive (ewiz; $30.99)
I am thinking of overclocking the E5200 to 300 mhz, but other than that, everything will be as be (I think/hope!).
Thanks again to everyone!
KeypoX
3,655
Was the issue with the bios being reset fixed? On the ds3l?
scootermaster
2,411
New thread? HA!
I don't believe it. I think you'll just wait until the one year anniversary of this one. :D
But seriously...is the 10.5.8/whatever thingee for the DS3L up already?
Nov 26, 2005
15,166
390
So my Adaptec SCSI replacement HDD setup came in today and it is defective. Didn't even plug it in. I took it out of the static bag to check it out before preping and you could actually hear loose parts inside the drive crashing around. Either bad packaging by NE or... don't know....
tbooth
210
Need Bluetooth?
http://tinyurl.com/6oxc95
-$2.50 shipped
-Class 1
-Natively supported (shows up in Menubar)
-No drivers needed!
I ordered one of these and my hack doesn't recognize it at all. It works fine in Windows though. Anyone else having a problem with these?
scootermaster
2,411
Need Bluetooth?
-$2.50 shipped
-Class 1
-No drivers needed!
Ooooh! I need/want bluetooth since my hack doesn't really recognize the stick that comes with logitech stuff (although it still works).
The cheapest "supported" dongle I've seen is like $25 from newegg, and it's not worth that much to me. So any word on what's a good BT dongle that works under hack?
mosslack
902
hq-a.weebly.com
That sucks, but I've BTDT before also with items ordered from most all suppliers. Having worked for the USPS for 16 years now I can tell you that packages are NOT treated gently at most stages of the shipping process. I mostly have had good experiences with NewEgg though.
:gift:
Nov 26, 2005
15,166
390
:gift:
Sounded like there were loose marbles inside the drive - haah
Cheers
Jack Flash
1,947
Just wanted to chime in that three months later I am still so happy with my decision to sell off my iMac and build my Hackintosh. Thanks again to Kaido! Without him I'd never had done it.
Now, I wanted to know if there's a natively working 802.11b/g/n WiFi adapter. Don't want to use Ralink's utility, though it does work.
Kaido
Feb 14, 2004
48,732
5,470
On eBay, there's a PCI card that has a Mini-PCI card (or PCIe?) inside. You can use either a Dell 1505 or Apple Airport card in it. It's plug-and-play for 802.11n.
Glad to hear your system is working out for you :)
Status
