- Feb 14, 2004
- 48,732
- 5,470
- 136
Originally posted by: Hernandito
Originally posted by: Kaido
Got the new 10.5.7 kit with the updated audio drivers up! Anyone wanna give it a try and report back with their success?
http://www.mediafire.com/file/...g3mgj/ud3p_waikiki.zip
Last file-related thing to do is test the DS3L kit (make sure it works properly), then I'm good to go as far as the kits are concerned. That UD3P kit above also includes a special folder in the SOUPKIT directory on the Magic Boot Disc that has the audio patch kit (10.5.6 AppleHDA.kext + Kext Helper), so you can re-patch the audio instantly for future point updates. The rest is just updating links and then starting a new thread!![]()
Hi Kaido,
I am in the process of trying this.
Is this the right order?
1) Install Leopard 10.5.4
2) Reboot with 123 and install 10.5.7 (do not reboot)
3) Install the Audio kext via the included kext helper app
4) Now we reboot
5) Run UInstall to add bootloader.
Please let me know. I have been trying to get this to work for 2 weeks. Thank you!!!
Hernando
1. Setup BIOS settings
2. Make sure your RAM is Memtested PLEASE!!
3. Install Leopard, setup, get to desktop
4. Install 10.5.7, reboot
5. Install Uinstaller (new one has everything)
That's it, pretty simple - OS, update, drivers. I'll be on for a bit, so LMK how it goes!
