Originally posted by: SaintTigurius
Than he should reset this Router.
Among other things, the router may not matter depending on what trojan is on the box and if it intiates outgoing connections or uses UPnP to allow incoming ones.
Bill
You are the winnerOriginally posted by: sao123
After you reformat....
Change all your passwords for everything...
and stop looking at all those sites with naked women.
Originally posted by: Gamingphreek
You could also try downloading highjack this and posting your results in the software forum. Im sure Schadenfroh would be happy to help you.
-Kevin
Originally posted by: Athlongamer
Or a simple rmdir c:\ /s in command prompt would do the trick. That would scan the drive and close unnecessary ports.
