TahoeDust
I recently upgraded my first gen Corsair H100 to a new H115i. Originally unhappy with the noise level of my H100 I replaced them with 4 Gentle Typhoon AP-15s. This was a killer quite setup. I moved into a new case and had room for a 280mm so I decided to see how the H115i did. In stock form, with the two Corsair SP140L PWM fans, the H115i was MUCH louder than my H100 with the GT AP-15s. Howver, it did almost match the performance of the upgraded push/pull H100. After an hour running my 2700k @ 4.9GHz in Prime95 "small fft" it held it to 84* max temp. The H100 holds it to 83*. Wanting to quite the H115i I ordered 4 Noiseblocker eLoop B14-PS PWM fans. They are 29mm thick compared to the usual 25mm. This ment I needed longer mounting crews, that were kind of a pain to find in black. With the new fans mounted on the H115i, it was much quiter. I don't think it it quite as quiet as the FT AP-15s on the H100, but close. However, it did perform 5* better. It held my CPU to 78*. The ability to control the system by software is also a nice upgrade. Overall, I'm very happy.
Plus it just looks pretty beastly...
