I have a Corsair H100i V2 AIO and a Intel 7700K running at stock currently.
1.175v @ stock idle = 28-35C (4.5GHZ)
1.175v @ stock load = 55-65C (4.5GHZ)
1.175v @ stock stress = 65-70C (4.5GHZ)
Pump Temp = 26-30C
Fan Speed = 900-2500RPM
Pump Speed = 2000-3000RPM
1.25 @ 4.9 idle = 35-40C
1.25 @ 4.9 load = 60-70C
1.25 @ 4.9 stress = 75-80C
Pump Temp = 30-32C
Radiator is top mounted in exhaust, 2 fans in front as intake and 1 read as exhaust using a Phantke Evolv ATX Glass case. Inside of case feels cool, pumps and tubes feel cool the air coming out is cool... I can't see how or why the CPU would be getting so hot. My buddy has a S340 with a Cryorig H7 and 7700K @ 1.2v stock his doesn't get any hotter then 60c while gaming.
I reseated the cooler and everything twice, used MX-4 paste I tried fans and pump on max... Voltages don't exceed 1.25v. Do these temps seem normal? I know that these processors run hot and Corsair H100i's aren't exactly top notch but I felt performance should be better... Should I return the cooler for a better one? I mean the liquid is 30c... pump seems functional etc so I just can't see what the deal is... when I took the cooler off thermal paste was evenly distributed etc. didnt' seem like a bad mount. These temps normal or should I rma the CPU and/or buy a different cooler?
These are temps while playing a basic game like Diablo II. So I can only imagine other games will make it even higher.
Pump Temp = 26-30C
Pump Temp = 30-32C
