my h100 performance were not so good.
I dont use it atm and i was wondering if i can open it and find what s wrong with it
Make sure the water block is seated, mine needed washers to make good contact. Changing the fans to Notcuas or AP-15's will help alot as they do not have the gaps on all for sides that draw air from in front of the rad instead of thru it like the corsairs.
I would change the fans to AP-15's and see what you get, you can always add two more for push pull. You should be 3-5C better with 2 AP-15"s.
I wouldn't recommend it, that would void your warranty. H100 does have a 5 year warranty, I would take advantage of that if your cooler is still within that time frame.
Try what have been suggested above, reseat the pump and make sure that your pump is running within spec. It should be around 2200rpm.
