guys, i have a little bit of a silly question...
kc2gub
162
i built a new computer, i love it, i had no problems at all, as this is my 3rd built computer, but how the heck do i mount the floppy in my case, lol.. Its a chieftec case, and for the cdroms i used the drive rails...but the floppy just sits in the bay... no room for drive rails, and no where to screw that i see....what am i missing...
Bovinicus
3,145
The cage the floppy drive is held in might be removable. Once you remove it, some available screw holes could be revealed.
kc2gub
162
hmm could be, let me look...
edit-i just checked, well what to you know, there were 2 thumb screws that removed the cage...thanks for your help, i looked to quick
buleyb
1,301
Yeah, that the same style where you take off the front bezel, and remove two thumbscrews to remove the cage through the front? :)
