Guitar Thread ... Look what i just bought
TheVrolok
24,254
4,092
Are you going to be able to reach it to change the battery though? If you have to unstring your guitar everytime you need a new 9V, that'll suck :)
Unstringing/restringing per 20-30 hours of playtime? That would get old .. fast.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
The cavity is in the back of the guitar.
Fritzo
41,920
2,161
OK cool. Last tip (promise! :D ) Make sure the wiring is well insulated. With the extra voltage going through the pickups they'll tend to be noisy if the wiring isn't insulated. Most kits will come with insulated replacement wire, but you have to be careful about the soldier points as that's where you'll get the signal bleed (a lot of people use shrink caps on their points for this reason.).
I'll be interested to hear how it comes out! Be sure to post some clips.
Invisible Evil
1,050
I have primarily used Duncan pickups (SH2/TB4) in every guitar I have ever owned. However I purchased an ESP Viper with stock EMG 81/85 config and was blown away at the clarity they have.
DaTT
Garage Moderator
Moderator
Feb 13, 2003
13,295
122
This is actually a solder-less set. Everything clips together.....except for the selector switch.
