Guitar Question for you experts...
Masas
664
I'm in the market for a new guitar...
playing level is pretty decent, not an expert yet, but i can play most songs with the tabs and just getting in to scales and pentatonics and such...
but i'm having trouble what to look for...
I definately want an electric, and currently own a bottom line Ibanez RG....
I want to know what each brand of guitars "sound" like and what their advantages/disadvantages are....
also what effect the humbuckers, pickups, and other aftermarket upgradable parts do...
i have $400~$500 to spend...
help me out~:)
Citation
230
I guess that all depends on what you want to play. I am currently in love with the ESP brand. For heavier stuff I think they are great!!! You said you have an Ibanez, thats what I got right now, and its pretty good too, another better choice from playing heavier things. But definatly look into ESP.
-Cit
Burnt
2,211
Get a gibson sg faded special, theyre around $550 from guitartrader.com. Or look for a used Fender MIJ Standard strat or tele, the ones made in japan are equally as good as the ones made in america (which is why they don't make them in japan anymore). I bought an '89 fender japanese strat off ebay for 275 and I think it plays wonderful
faZZter
1,202
I like Stratocasters myself.
But like the other guy said, it just depends what kinda music you are into. Also it helps to just go to the guitar shops and try them out for awhile to see what the sound and feel is like.
The Fender Strat can have a real crisp clean sound, it can do blues like clapton, or rock like Smashing pumpkins. Great all around guitar IMHO.
Eli
Super Moderator | Elite Member
8
If you're into metal, definately get an ESP.. and then slap EMG-81s in there. ;)
Mucman
7,246
Not sure any of us can answer your question... a guitar is a very personal attachment of your personality. I heard thousand dollar guitars and pawn shop cheapies... they all have a unique tone that can be attractive to the right person. Not really sure what else to say... just go around and fondle some axes and you will find the right one for you ;)
yellowperil
4,598
Like said above I think it depends on what sound you like. The Stratocaster or Les Paul are probably the most versatile because they are used in every type of music. As far as pickups, generally humbuckers are described as having a warmer and fatter tone than single coils, but single coils sound 'cleaner'. Single coils are subject to 60Hz hum (unless they are noiseless) and humbuckers aren't, because they are two single coils wound in reverse polarity to cancel out the hum.
Feanor727
411
well it largely depends on what your personal preference is. in the realm of electric guitars there are basically two types. The first type has 3 single coil pickups. i.e. Fender Stratocaster. The second type has 2 humbuckers, or double coil pickups, i.e. Les Paul. Everything else pretty much stems out from there. There are some exceptions, i.e. the Fender telecaster or certain early-model Gibson guitars with P-90s, but that pretty much covers the basics. They each have a distinct tone, and pretty much the only way you can decide which one you like better is to play as many different guitars of both types as possible. People will tell you "Oh, if you want to play metal you _have_ to get an *insert one of Ibanez, B.C.Rich, ESP, Washburn, blah, blah, blah*, but that's a load of bull. Kirk Hammett (of Metallica fame) regularly uses strat-type guitars. You can play whatever type of music on whatever type of guitar you want, as long as _you_ like the sound. That being said, if you want a "classic" sound, then you're probably going to want a "traditional" guitar. In other words, if there's a guitar player whose sound you idolize, then go find out what their rig is and copy it. After 10+ years of playing you may be able to passably sound somewhat like them. If you pick a sound/style you like, the only limitation is your skill.
but enough with the rant. Guitars in your price range. If I had $500 to spend on a guitar today, I would more than likely buy a Fender Strat. doesn't matter if it's made in Japan or the U.S. or Mexico as long as it sounds good. One of the tricky things with fender guitars is you can have 2 guitars that are exactly the same year and model, but one may sound good, and the other may sound like crap. Caveat Emptor. Another option is G&L. You have to order new models online, but you may be able to find a used one or two in a local music store. Their models are similar to fender's, but about a thousand times better in terms of sound and construction quality. If you despise single-coils, then try to find a used Les Paul or SG. And whatever you do, make sure it's a Gibson. Epiphone's aren't good for much else than firewood. Ibanez's are all right, but I prefer the higher-end models like the Joe Satriani or Steve Vai signatures. Musicman makes a fairly decent guitar as well, but they may be a bit out of your price range.
