- May 12, 2001
- 12,452
- 2
- 0
I'm going for a slightly CRUNCHY sound, very slightly distorted, just real edgy, how do i get that? Go with a generic pedal and turn it up a bit?
Originally posted by: thomsbrain
the Ibenez TS-9 Tube Screamer is what you are looking for. i recommend against boss, but you should try out the pedals yourself to make sure. some people like boss. personally, i think they sound generic, and many of their digital effects sound brittle and metallic. that said, boss makes a killer phaser, the best i've tried. but definetely try out the TS-9. it's a legend, used by tons of pros. it's also great for kicking the jams out of classic tube amps (hence the name).good luck in your search, i hope you find what you're looking for.
