im looking to do some modifications to several pieces of cooling hardware and i need advice on what to get for polishing copper and silver base heatsinks to a mirror finish. i have a vendetta2 that im planning on modifying with either silver or copper sheet using a butane torch to fill in the gaps between the heat pipes and the retaining block the pipes are mounted in, and once im done i would like to lap the surface to a mirror finish so it isnt uneven. i have looked around online for wet/dry sanding material but im not really sure what to get. does anyone have any recommendations? also, i have seen several recommended methods for sanding metal surfaces to a mirror finish, but what is the recommended method for CPU ISH/Heatsinks?
