Nothin[b said:
g[/b]man;32982967]1 of his claims out of 3 has merit, the other 3 are dubious at best. And since he's the one offering it as things people should do to optimize their system, the burden of proof is on him. Just saying something with a large font doesn't make it so.
Large font makes the documentation more professional. It's supposed to be done that way. Whether the information is perfect or less than stellar, it has nothing to do with making large bold fonts. This makes it easier for viewers to read too.
Everyone likes to blame the registry for things that aren't its fault. It's become a whipping boy for lots of problems just because people don't understand it.
And at the same time we have bunch of people "blame" on malware infection which may have nothing to do with registry problem. You simply say "because of malware" that instantly makes the user ignorant too. It's not that simple as you think when it comes to registry and windows file system.
I used XP as my main workstation for at least 2 of the last 3 years straight without any random registry corruption or issues. MS isn't perfect and has caused issues for people with updates and such, and I'm shy...
Problems with system failing due to Windows updates
IS registry related. Everything is composed of registry in Windoz
🙂D) environment.
99% of the time it's some 3rd party software that included an explorer extension, IE add-on, filter driver, etc that is the true cause of problem.
First, it's not 99% of the time. Problems caused by add-on's on IE is registry related. They are all handled by registry! And of course they often get registry corruptions too. So that 99% (with 1% being hardware problem) problem is with registry.
That would be a pretty drastic change from the previous behavior of just giving you a new directory (e.g. username.domain or username.000) but I wouldn't discount it. I'll have to give that a try in a VM and see what happens.
And that is no problem what-so-ever in Windows 2000/XP/2003. For security concern, it's a clear downgrade for Windows 7, or should I say "
clear devastation".
When you change the name of the folder, it will not notify you with any alerts or popup box saying
"Man, you are f#@ked if you change this folder name coz if you log back on all data will get wipped and you be f#@ked for good" or something similar in more appropriate way so you know what's coming ahead... :$
"The registry sucks" isn't helpful in any way and blindly repeating it over and over just removes any credit you may have had because either you don't know what you're talking about or you can't articulate the details.
It's sometimes difficult to specify what is the culprit in the software because ALL IS MADE UP OF REGISTRY... You can start off with the error messages and error codes and do research. They are all registry problems.
Actually, I have a great learning tip for you Nothingman. Think of registry as DNA of a human body. It tells where your nose and mouth should be located and how they function and behave. It's a complete set of instructions and database. Good advice.
