GTX580 Temps
Isn't 90 °C the stock load temperature anyway? If it's stock then it's been tested to work at that temperature. I would try to run the fan higher since lower temperatures will help with longevity.
The reason I ask is that I am getting code crashes on my GTX580s but no crash on my other cards that run a lot cooler (e.g., Tesla). =\
You'll have to use a combo of nibitor and nvflash.
I don't know if nibitor has a linux version however.
Otherwise you can ask someone to make one for you.
Edit: This should get you started: http://www.overclock.net/t/989627/fermi-bios-editor-gtx-4-5-series
Most of it is Windows based though, Linux is pretty bad when it comes to enthusiast oriented software support.
But if you have a Windows box you can use it to create your modified bios and then flash on any system with a bootable usb.
I guess there is no way to do it if I don't have physical access to the cards? =\
The hardware isn't mine, pretty sure they won't approve a BIOS flash not from the OEM.. =[
Kind of confused, they're not yours and they're not stable? What's your connection to the hardware, are you renting it from a company who is giving you remote access?
The relationship is complicated 😉
They're locked up in a sever room somewhere, I supposed I could get physical access.. but it'll still be a pain in the ass. Plus, flashing non-OEM BIOS is almost certainly never going to be approved.
