Gtx570 will not fit (sata)
Status
Not open for further replies.
boman744
35
So ive got a question regarding my topic..
Intel board. ICS-003 Class B
Im guessing this is the model of my board?
Anyways, the 570 fits, but covers 4 out of 6 SATA ports on my mobo. I have 3 sata cables:
Harddrive
Diskdrive
And another from front of case.
Is the one from the front of the case needed? Is that what controls the power and reset buttons on my tower??
Tower is - Antec 902
I dont think 90 degree sata cables will fit... It is verrrrrry tight.
Also the card covers 4 black ports, leaving 2 red ports. Can i just hook up the hdd and diskdrive?
This is no fun.. Thanks for your advice!
skipsneeky2
5,035
One going to the front of the case is a external sata i believe i owned one and i never hooked up mine just added clutter inside the case.
You can go without them and i'm assuming your using a ide dvd rom drive?
boman744
35
Sorry idont know what an ide is..
But yes its dvd rom.
So the sata cable from the front of case has nothing to do with the power and reset buttons? I can eliminate that?
There are 2 usb ports, audio in, mic in, hdmi (it looks like) and the power+reset
bryanW1995
11,144
32
Do you have any other wires connecting from the case? In every case that I've used there were 5-6 little individual wires that I had to hookup to the mobo for pwr/rst/etc.
I usually hook up the external usb adapters on my antec 900 cases, but on my current build I didn't bother.
boman744
35
Yes there are! Hmm
6 wires---
Front panel
Power LED
Hopefully that is relating to the power switch?
I will install everything and see if this works without this sata.
Mind you, i will be connecting to the two red sata ports now.. Not sure if that is going to be a problem.
Puppies04
5,909
17
The sata cable from the front of your case will be for esata, if you find another one it will be for a hot swap hdd. They have nothing to do with your power buttons :D
BFG10K
22,709
3,005
Boman744, don't start a new thread every time you run into a problem installing this card.
Super Moderator BFG10K.
Status
