Depends on the application. Some rendering and modeling applications benefit greatly from "professional" level cards' drivers. (They're the same as cheaper cards, but with better drivers.)
A fairly good pro GPU is equivalent to a 750ti. So for applications that don't benefit from those drivers a 950 should be fine.
