GTX 950 3D MARK LOW SCORE, FPS low etc.
Rasty1991
15
Hello,
sorry for my English I am from Europe.
I bought my ASUS GTX950-M-2GD5 few weeks ago and I dont know why I am getting low score on my gtx 950 fire strike-3d Mark score. I have clean Windows 10 installed and all drivers updated, no virus etc..
Here is my score: http://www.3dmark.com/fs/6729583.
And even when i look for someone to compare with my score. Usually that person get like 5700-6000 score. I got like 5300-5380 score when I am lucky one. So why i got this low score? I now that this card has little lower Gpu clock speed, but I dont believe it does that too much difference and even I can find someone whit same clock speed and that person get much more score. My fps in games is problem too, when i compare to someone with my card.
So what is going on with my card. Thanks for any help.
I really appreciate it.
LTC8K6
28,520
1,576
AMD FX-8300
MSI 760GM-P23
Probably those two are the problem.
DDR3 @ 667 MHz
And that.
But really, it's only a GTX950.
Rasty1991
15
As I said I can compare with someone even worse spec then me on 3D Mark like worse CPU and same Ram and he got this higher score. What is wrong with this motherboard? I now its old but how can It affect score that much. And what do you mean its only 950.....
Can someone else help me thanks.
LTC8K6
28,520
1,576
What "worse" cpu?
Got a link?
Rasty1991
15
Nevermind I looked again and they have similar score, usually they get better score because they have oc they 8300 processor, but can I ask another question? Why i have only 3600 GHz turbo boost on 3d Mark results. Is it because I have this old motherboard or I have low power supply? I have only 450W power supply.
Rasty1991
15
I set my power plan option to high performance and still I get only 3600 Mhz turbo boost at 3D mark. Cant be problem somewhere in bios ? Something is wrong set or is it really my power supply? I got Cpu-Z screen if it helps somehow.
http://postimg.org/image/jhgo132t5/
Seba
1,599
259
What CPU cooler do you have?
What is the CPU temperature in full load?
Your CPU multiplier ranges from 7 to 21. That means your CPU can vary its frequency from 1.4GHz to 4.2GHz.
LTC8K6
28,520
1,576
Try running the CPU-Z benchmark while watching the CPU speed with another program like Throttle Stop.
I think it may get to 4.2 with a lighter load.
Rasty1991
15
Ok my temperature is around 49-50 ºC when I am playing assasins creed syndicate and cpu core speed never reach over 3.6 GHz and when I stress cpu in cpu-z same results.. Cpu core speed not reach over 3.6 Ghz
