Hi guys how are you?
I`m a little scared about my video cards
Sometimes it just start appearing a lot of artefacts in the screen gaming, no overclock, nothing
I have here 2 GTX 780 SLI, i only tested at Payday 2 game till now, i can play for hours without a problem, and then it starts, if i close the game and start again no issues, or if i use 3dmark no issues either
i have the TDR issues here related to the Nvidia drivers, that will be fixed in the new one that will be released in the end of August
But i`m really sad thinkinbg that some of my cards might have a problem
Is there a way to test it without putting off the machine one or another?
And what i described means a hardware issue?
My system is an i7 3770k @ 4.5
PSU CoolerMaster SilentProGold 1200w
The cards are EVGA SC Edition
Thanks
Edit1: Well guys, runned the Valley Benchmark in the max possible for 3 hours and nothing happened, runned with SLI off but with both cards attached so just the first card was running right?
No issues at all, what should i do now?
Thanks
Edit 2: Did the same with the bottom card and no issues again
Edit 3: Trying Furmak now, till now no issues, temps normal, with SLI off but both cards attached, is it really enough just to disable SLI and switch the monitor cable to test each card individually?
Thanks
Thanks
Thanks
Thanks
