GTX 760 with fps problems
As005
I am experiencing pretty severe frame drops while playing counter strike and I can't figure out what the issue is. I've updated all of the drivers for the mobo and gpu as that was the only thing I could think to do. I get over 100 frames for the most part, but it dips into the teens often and I have tried some different graphic settings but I lowered them and found that it helped but not very much.
everything is low, anti aliasing is off, and just about everything else off that effects the frame rate. I have a screenshot that I'll post as a reply once I'm back at my computer. Anyways, I don't know what else to do after I've reinstalled all the drivers and lowered my settings. Any help is appreciated.
System:
ASRock z87 extreme4 motherboard
MSI GTX760 GPU
intel i5 4670k Processor
8gb vengeance ram
Windows 8 64 bit
I was about to suggest DPC Latency Checker, but then I was reminded upon looking it up that it has problems with accuracy when run on Windows 8.
Here it is anyway:
http://www.thesycon.de/deu/latency_check.shtml
For the one time that I had a issue like this several years back, it was the driver for a PCI wireless LAN adapter. Every few seconds the utilization on the bus would spike for no apparent reason. Replacing the adapter fixed the problem.
