Has anyone encountered problems resuming from S3 sleep?
Since putting the GTX 680 in (and taking the 480s out) my computer doesn't come out of S3 sleep anymore. It wakes up, and immediately reboots itself after a supposed BSOD which I can't really see. Everything worked perfect with the 480s. I don't think it's the driver, because I had the 301.10 installed on the 480s with a modded inf and everything worked fine.
Anybody else experiencing similar? Managed to find one forum post that seems linked to my issue
http://forums.nvidia.com/index.php?showtopic=226284
This is what I've pulled out of event log
Code:
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 4/1/2012 11:13:37 AM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (2)
User: SYSTEM
Computer: CLASSIFIED
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>2</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000000000000002</Keywords>
<TimeCreated SystemTime="2012-04-01T15:13:37.025606200Z" />
<EventRecordID>14287</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>CLASSIFIED</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">80</Data>
<Data Name="BugcheckParameter1">0xfffff880904c5000</Data>
<Data Name="BugcheckParameter2">0x1</Data>
<Data Name="BugcheckParameter3">0xfffff8800f20406a</Data>
<Data Name="BugcheckParameter4">0x5</Data>
<Data Name="SleepInProgress">true</Data>
<Data Name="PowerButtonTimestamp">0</Data>
</EventData>
</Event>
Log Name: System
Source: Microsoft-Windows-WER-SystemErrorReporting
Date: 4/1/2012 11:13:44 AM
Event ID: 1001
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Description:
The computer has rebooted from a bugcheck. The bugcheck was: 0x00000050 (0xfffff880904c5000, 0x0000000000000001, 0xfffff8800f20406a, 0x0000000000000005). A dump was saved in: C:\Windows\MEMORY.DMP. Report Id: 040112-11044-01.
Event Xml:
<System>
<Provider Name="Microsoft-Windows-WER-SystemErrorReporting" Guid="{ABCE23E7-DE45-4366-8631-84FA6C525952}" EventSourceName="BugCheck" />
<EventID Qualifiers="16384">1001</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2012-04-01T15:13:44.000000000Z" />
<EventRecordID>14288</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Security />
</System>
<EventData>
<Data Name="param1">0x00000050 (0xfffff880904c5000, 0x0000000000000001, 0xfffff8800f20406a, 0x0000000000000005)</Data>
<Data Name="param2">C:\Windows\MEMORY.DMP</Data>
<Data Name="param3">040112-11044-01</Data>
</EventData>
</Event>
