- May 16, 2008
- 3,180
- 0
- 0
I was just reading up on the 670 power edition and was kind of surprised by TechPowerup's results, both for this card and in general. The overclocks they've achieved are in general not too special. (670s, 680s, and one 7970)
http://www.techpowerup.com/reviews/MSI/GTX_670_Power_Edition/31.html
Card: Core: Memory:
MSI GTX 670 Power Edition 1055 MHz 1820 MHz
GIGABYTE GTX 670 OC 1060 MHz 1925 MHz
ZOTAC GTX 670 AMP! 1150 MHz 1890 MHz
NVIDIA GTX 670 1100 MHz 1760 MHz
ASUS GTX 670 DirectCU II 1110 MHz 1890 MHz
Palit GTX 670 JetStream 1120 MHz 1750 MHz
NVIDIA GTX 680 1147 MHz 1833 MHz
ASUS GTX 680 DirectCU II 1207 MHz 1766 MHz
AMD HD 7970 1075 MHz 1715 MHz
While on the other hand hardwarecanucks had quite the opposite results:
http://www.hardwarecanucks.com/foru...6-msi-gtx-670-power-edition-oc-review-20.html
the GPU hit an impressive 1388MHz while the memory petered out at 6524MHz
Guru3D got in between.
http://www.guru3d.com/articles_pages/msi_geforce_gtx_670_power_edition_oc_review,24.html
Core Clock: +100 MHz
Boost Clock: ~1300 MHz
Memory Clock: 7012 MHz
KitGuru got somewhere between too.
1202/1280 boost
http://www.kitguru.net/components/g...670-power-edition-oc-twin-frozr-iv-review/20/
I'm curious to see how the GPU lottery turns out tomorrow. At least it has a decent cooler and easily matches the 680 at stock clocks. Any PE owners out there? How does your card do?
Apparently you need the older afterburner 2.2.3 or you have to edit the config on the 2.2.4 to overvolt. I'll have to check into that more.
I'll try get some benches from BL2 as I'm extremely curious how it is relative to a 690 and where the minimums are.
Card: Core: Memory:
1202/1280 boost
