Yeah the setting still reverts.
I did the optimized defaults thing. The only real setting that I have to change is setting my hard drive to IDE as opposed to AHCI (does not let system boot).
So my motherboard has two PCIE. The video card did work the first time I changed it. The secondary slot, however, reduces performance so I reverted back to original. After the reversion the card wasn't detected and so I put it back in the secondary slot and then it was again not detected (this happened a couple of days ago).
At the moment it is being detected and running fully well (played black flags on highest settings - I am afraid to shutdown my computer). I think that something about the system shut down causes the graphic card thing to reset. I am not an engineer but does the graphic card have load up capacitors/battery, which it uses to start up? The graphic card is not detected for 48-72 hours after a shutdown, after which it suddenly reappears. Perhaps the battery/capacitor need to build the charge or something? That is my theory at least... not sure.
Of course, if the capacitors had gone completely bad then the card would not function perfectly well once detected (which it does). Its just that it is not detected for sometime after a reboot and randomly gets detected again.
