Hi all, just looking for a recommendation. I quite like the look of the thermalright ones and then sticking a good fan on it.
What do others use and also, if you saw a GTX670 on an auction site with a decent aftermarket cooler would that make you less willing to buy it or wouldn't it matter?
Knowing that eBay or PayPal will cover you if something doesn't work I can't see the problem with it. On that poiint tho, I'm guessing it's easy to just refit the original cooler onto it as long as thermal paste was applied correctly?
Let me know what ya think and also do you know what 120mm fan if I were to just buy a heat sink would be quietest?
I'm getting a bit sick o the reference cooler on my EVGA card.
