I am buying my brother's old 2 GTX 580 cards for $400 which I intended to drive 3 monitors. But as I began reading about them, I saw how power-hungry they are and that it would require me to buy a 1K-watt power supply. Now all the sudden this upgrade is getting more expensive.
I am a computer game developer and run both 3D apps and games on this PC.
I was considering some options:
1. Install 1 GTX 580 and 1 GT 640 in my workstation PC so I can do everything on it - work and gaming. Possible?
2. Get my other PC working, install GTX 580, and use it for dedicated gaming. Then install a GT 640 in my workstation PC to drive 3 monitors. Sell 2nd GTX 580 card. Buy 4th monitor.
3. Not buy the video cards and do something else.
I really just want to drive 3 monitors. What are my options? I would prefer to stick with nVidia and not have to upgrade my 750-watt power supply. It would be awesome if the card was good for professional apps AND could play games well. I hear the GTX 600 series has drastically dumbed-down the GPGPU side of things 🙁 I need precision for 3D Studio Max, otherwise I have all sorts of problems.
System Specifications:
I. Processor/CPU: AMD Phenom II 1100T
II. Current Graphics Card: GTX 470
III. Display Resolution: (1920x2)x1080
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age). If possible, please provide a link to a website containing the power supply specifications:
Antec Earthwatts 750-watt, 1-yr old
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent):
Rosewill Mid-tower, two fans on top, one fan in front panel
Purchase Details:
I. Budget? Please be sure to include currency (If not USD), retailer preferences & specify whether rebates are a viable option. $400
II. Any particular preferences (Manufacturer[nV or AMD], Brand[XFX, Sapphire, EVGA, etc], Cooling Solutions)? No brand pref - air cooling only
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI?
Yes - see my notes
IV. Have you previously looked at a product(s) which you feel would fit your needs?
Yes, various places
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
I play strategy games all the way up to modern FPS games, so my needs vary. I don't mind dumbing down details if I have to but prefer not to.
VI. Do you plan on overclocking the card you intend to purchase?
Negatory
Purchase Details:
Yes - see my notes
Yes, various places
Negatory
