That was a good question about Skyrim. Has anyone heard whether it was being developed with a particular optimization choice between nVidia and AMD?
I haven't heard about optimization but it uses the Havok engine, so no Nvidia boost for Physx.
GTX 560 Ti is available with 2GB RAM
the gtx570 is about the same price or cheaper after rebate and will be faster in every case at 1920x1080.GTX 560 Ti is available with 2GB RAM
OT:I'm in the middle of an Oblivion playthrough modded all to hell, and can actually run out of VRAM with 2GB(!) if I don't pick and choose which mods are enabled. Of course this is also a very extreme case, in general I'd say the 560 Ti fits your needs just fine.
its back in stock as of this morning...Thanks, hopefully the Galaxy card will be back in stock in the next few days at the same price.
While this is generally true, the one glaring exception is heavily texture-modded games such as Oblivion, GTAIV, and in all likelihood (as the OP mentioned being interested in) Skyrim.Doubt the extra 1gb vram is gonna make a difference even at higher then 1920x1080 reso.
I'm running just over 300 mods (using Wrye Bash to break the 255 active-mod limit) so it's pretty crazy, maybe I could PM you the whole list if you're interested. It's mostly stable. Most of the time.OT:
May I ask what mods you're using?
