- Aug 9, 2004
- 4,458
- 4
- 81
I built a system about two months ago with the following:
MSI 870-G54
Ph II X3 740
G.Skill DDR3 1333 low voltage
1TB Samsung F3
MSI GTX 460 Cyclone
Corsair CX400
Antec 200 case
The CPU was unlocked to four cores, overclocked, and tested stable but through general usage the user noticed some frequent system instability (BSOD's, downloaded file corruption, etc.). The system also used well below the output of the PSU. Subsequent stability tests showed that the system had become unstable and I returned the CPU to 3 cores and stock speeds, but it didn't help. The user then noticed graphical corruption in games, with vertical and horizontal dot matrices appearing on textures in games. This looked like a graphics error, so the GTX 460 was boxed up and RMA'd. However, when we booted up the system with a temporary AMD HD 4350 installed, the system stability returned and stayed stable even after unlocking the CPU to four cores and overclocking it.
Has anyone ever had a graphics card affect an entire system like this? I thought it may be a PSU or mobo issue, but again, the PSU is way below output threshold (like 250W max while stress testing).
MSI 870-G54
Ph II X3 740
1TB Samsung F3
MSI GTX 460 Cyclone
Corsair CX400
Antec 200 case
