TemjinGold
- Dec 16, 2006
- 3,050
- 65
- 91
Originally posted by: Extelleron
Originally posted by: Shmee
Would a corsair 750TX be good enough for 2 of these? Thinking of buying, rig in sig.
I have no problem with overclocked Core i7 + GTX 260-216 SLI and a TX750.
The GTX 280s do take quite a bit more power but they still should be fine:
http://www.bit-tech.net/hardwa...295-quad-sli-review/16
And their test setup is an i7 @ 3.7GHz, which I am pretty sure will take more power than your Q6600 @ 3.3GHz. Although you may be hitting into a bit of a CPU bottleneck with 280 SLI on a Q6600 at those speeds.
http://www.guru3d.com/article/...-performance-review/19
Dang... according to that first link, the peak power draw for 280 is under 400 watts so I should be good with my HX520.
