Archangel1977
I will try to be short here are my specifications:
I7 980x 3.33Ghz Gulftown socket 1366
Asus Rampage III Extreme 1601 BIOS
Corsair Dominator 6GB (3x2GB) 2006Mhz 8-8-8-24 1.65v
X-25M Intel SSD 80Gb
Asus ENGTX280 1GB DDR3 x2
Silverston Olympus 1200W PSU
The problem is that I get a BSOD when both Video cards are enabled on the motherboard( The asus rampage III extreme has jumper switches that turn on and off every PCI-E slot).When i close the card placed on slot 3 and stay with the card on slot 1,the PC boots into windows just fine...Things i have tried:
1.Reinstalled Windows from scratch
2.Tried 15 versions of Nvidia Drivers
3.Reflashed the motherboard BIOS
4.I have closed the card(working one) on the board and connected the monitor on 2nd card (the faulty one propably) and get no video signal but i can see the USB's posting and the lights on the PC working...everything except the video post...
The PC boots into safe mode just fine with both cards and recognizes them and i can install the drivers for them,but then when i try with both enabled to enter normally into windows it results in a BSOD,with the message "Page_fault_in_nonpaged_area",or sometimes I get the same error message with a failure about nvlddmkm.sys.I just want to know if there is a way to test if the 2nd card has gone bad...
I cannot uninstall the card to check it to another PC,cause the whole system is watercooled,so that means need to find a way to check it on this board...Anyone any ideas on the matter...?
