gtx 280 105c hot + mk 13 vga cooler = 50c hot under full load
alanwest09872
1,100
Just as my title states. I was having huge issues with 2 of my sli graphics cards. I accidently damaged one but lets not get into that its on a different post. So I placed this one on another gtx 280 that ran at 105c after I placed it on the temp droped down to about 35c and under full load 50c. So if anyone is having an issue with heat on that card pick up the mk13 it works awesome. I should also state that I havent placed any fans on this yet. They recommend to have 2 to 4 fans blowing on it. I have one from outside the case. (one side of the case is off) and with just that it keeps it super cool.
its only 80 bucks and is super easy to put on. The only thing that sucked was the 2 screws that hold the card board to the other piece of plastic. Those needed plyers to get undone.
Oh the heat syncs kept falling off also they were a bit of a pain but def worth the hassel.
