GTX 1080 FE + GTX 980ti Hybrid Radiator OC/Temp results
Annisman*
1,931
95
Core: + 225
Memory: + 575
In game I am getting 2.126 Ghz constant on the core and 11.160 Ghz effective memory.
Going any higher than +575 on the memory kicks in ECC and drops my benchmark scores.
Idle temp is 28C and load temps don't go above 45C :)
Install was incredibly easy, I had purchased an Accelero Xtreme IV cooler but seeing this and how simple it looked I went with the hybrid instead and I'm glad I did. Only one hiccup, when detaching the blower wires I accidentally snipped one of them clean in half ! So now my blower runs 100% speed 24/7 hahaha debating on whether I should unplug it and hope my VRM's don't need all that cooling, what to do what to do...
The blower doesn't spin up to 100% until windows loads, anyone know what that is telling me ? Have I completely lost software control of the fan or might there be hope ?
thilanliyan
12,085
2,281
Could you tell me what the hole spacing is on the stock heatsink?
Meaning diagonal length as well as the side length.
fastamdman
1,335
70
Well done minus the wire issue ;) Really clean setup, good job. Those temps are amazing.
guskline
5,338
476
Nice job!👍😎. I have my FE under water with an EK waterblock. Runs cool.
Annisman*
1,931
95
I actually ended up unplugging the blower fan altogether. I put a 140mm directly below it to cool the VRM's and memory. It's ridiculously silent now. Gus what are your temps and clocks ?
