The card runs fine clocked at the speed in my sig. But it sure is loud and runs kinda toasty.
61C idle, about 80C during gaming. I tried using nibitor to adjust the fan speeds in the bios, but it doesn't work. 20% fan speed at idle, not sure if it gets to 100% or not under full load.
So I dusted off a VF900, and while the idle speeds dropped 10C, to my surprise it maxed out at 86C. Hooked up a fan controller, and nothing really changed.
Went back to the stock cooler with the fan controller. I guess the noise is somewhat under control, I turn it all the way down for browsing and it isn't too bad. Turn it to 100% for gaming and it makes some serious noise, but that doesn't bother me much during all the fragging and explosions.
The temps are still the same, no change. Problem is I have a Ultra Microfly and any aftermarket cooler has to be the same width as the video card. It sits right underneath the power supply, so no heatpipes are extra big fans/sinks can stick out. It can use 2 slots, but the third slot is taken.
According to GPUz, the card is 65nm, I thought all GTS250's were 55nm? I guess not:frown:
Does anyone have any suggestions for a gpu cooler that will fit?
