GTO and GTO2 questions
Finns14
Ok so what are the chances of me buying a GTO2 and it not being modd-able now I'm also see things that the GTO is also modd-able so would be the difference between the GTO and the GTO2 if they were both modded? Anything? Also whats the chances of the GTO being modd-able. Please hurry I saw how much the GTO2 rose in price once ppl found out about this mod so if GTO is just as good as the GTO2 modded I wanan jump on this quick. Thanks so much
From what I've read, the gto2 always unlocks to 16 pipes successfully, but the OC'ability varies from card to card. But even a "bad" gto2 will still hit at least 500 on the core, which is a 100mhz overclock. The gto2 also comes with 1.6ns mem, rated at 1200mhz ddr, and it usually can run at least 1100mhz stable.
The problem is that all the gto2's are either sold out or overpriced. $250 or more is not a good deal on it. I missed the opportunity to snag one up at $199, so instead I ordered a Connect3d x800gto - many people have successfully unlocked those as well, but some dont unlock, so it's not guaranteed. The c3d gto uses the r423 core (as opposed to the r480 on the gto2) which is the same as a x800xt, not the x850xt. It also has 2ns mem rated at 1000mhz ddr, but with decent cooling many people are getting past 500mhz on the core and past 1000mhz on mem, so for $179 from monarchcomputer it has the potential to unlock and perform as fast or almost as fast as an unlocked gto2.
From what I know, only the connect3d gto has a chance of being unlocked, so get that one if you cant get a gto2.
Munky thats an uber rig you got there!! Let me know when you decide to part it out. My athlon 128 can only hit 9.99 ghz stable on cold milk.
Originally posted by: tekkitan
isnt the only company manufacturing the GTO2, Sapphire?
Yes, only Sapphire makes the gto2. But it's almost impossible to find one now, and a connect3d gto (not gto2) also has a chance of being unlocked, but for a lot cheaper.
I heard the PlayStation9 will transmit video directly into your brain, so that will make my rig obsolete by then.
hahaahah nice rig. 😉
Anyway i have a GTO^2 and with the ATi Silencer (oh yes you probably will have to buy one of these too to get a stable OC!) I can get about 535/610 stable although I run it at 520/600 as I dont see the need for it to be any higher at the moment. I came from a 9800pro and the improvement has been immense. higher framerates allround at HIGHER settings. you should love the performance increase.
I dont see the point shelling out for a top card now anyway with R600 around the corner (Q4 2006) that card will bring about a big change. if u play at 1280x1024 this card is enough for most current games to be played comfortably. (fear being the exception)
that would be sweet though, you wouldn't even need a tv. That would be wayyyy better than HD-tv. imagine unlimited resolution.
