- Mar 11, 2006
- 543
- 0
- 0
Originally posted by: Kromis
Times Busted: 0
Haha, reloading saves FTW!
Times Busted: 0
or just kill yourself so you don't lose your weapons
that's what I do
Times Busted: 0
that's what I do
Ya it's basically almost impossible to get busted in this game. You can run away when they catch you on foot, and you can drive away a lot easier than in previous games.
Times Busted: 0
Originally posted by: Sam25
Looks like some people are having problems with a 8800 GTS card:
http://forums.nvidia.com/lofiv.../index.php?t83529.html
check the aspect ratio setting to make sure it matches the aspect ratio of your resolution
Times Busted: 0
that's what I do
What the hell are you talking about? In previous games you could get rid of 5 stars by driving into a pay n spray. In this game the pay n spray never works and anything past 3 stars is basically impossible to escape.
Anyway, make sure you patch the game and install the latest beta Nvidia drivers. Beta drivers work just fine, but they can be updated more often because they don't go through all that testing and what not. Also, I remember games like BF1942 having fucked up text when anisotropic filtering was enabled. Turn AA and AF off (in nvidia control panel) to make sure those aren't causing this.
Times Busted: 0
that's what I do
I mean in SA and VC if the cop got anywhere near your car door, you were instantly arrested. But in GTA4, you can drive away even if his hand is on the handle.
Times Busted: 0
that's what I do
The way around that is to drive in reverse with the wheel turned away from the cop. If the cop is on the left side of the car, you drive in reverse with the wheels turned to the right. You'll drive over the cop![]()
ah that brings back memories..
