- Oct 26, 2012
- 2,059
- 674
- 136
I bought a refurbished Acer XB280HK ($350!) to supplement my delayed GTX 1070. The monitor came today and is replacing an existing 4k freesync panel from Samsung.
I haven't been able to find many users running a 4k Gsync panel (old DP 1.2) on an AMD card. I will be stuck on the R9 290 for another week it seems.
Anyways, I am having an awful intermittent signal loss with Displayport. The panel will go lose signal sporadically. If I make the Acer panel my primary display, the display will lose signal every 1-3 seconds for about 3-5 seconds until I add another display via HDMI. If I make the HDMI panel (tried Freesync 4k and a 1080p TV) as primary and allow the 4k gsync as secondary, the flickering is reduced 95%. It now loses connection once every half a minute or so.
So if I make the 4k Acer the secondary display, it works for the most part, letting me play games @ 4k with only a 3 second disconnect every 30-60 seconds. If I make the Acer my primary display, it constantly loses connection.
In Monitor settings, ULMB is greyed out which means GSYNC is enabled at least on the monitor's end. I cannot disable GSYNC unless I have an Nvidia GPU, correct?
I am assuming this monitor will not work with AMD and Intel GPU's? I bought it for the GTX 1070, and I am hopeful that the monitor has nothing wrong with it. This monitor has NO warranty. If I want to get my money back, I need to return it within 7 days. Is there some way I can verify that there is nothing wrong with it? Can anyone with a GSYNC monitor verify that it will not work properly with an AMD GPU? This flickering/disconnecting issue has me concerned. I won't be getting the GTX 1070 until later next week at the earliest due to shipping problems.
edit: I tried a custom 59Hz resolution to no avail. I will try to get to a Computer Store (2+ hour drive) with a mini DP -> DP for my Macbook Pro, as it has a GT 650M. I live in a very rural area where shipping is always slow and no electronics store is in the county.
