This shouldn't be too difficult of a question for most of you out there...
I just installed Redhat 7.2 because I was sick of Mandrake's incompatibilities (Ximian, etc.) and wanted to give a different distro a try (debian @ work, Redhat 7.2 on my laptop).
Anyway, when I installed Redhat, I'm dual booting (HD0 -> WINXP, HD1 -> Redhat), and had Grub installed in the block partition of hdb, so that I wouldn't install over WINXP's boot. I did this so my g/f can easily get into WINXP, and when I need to boot into Redhat, I just change the boot order in the bios...simple enough for me.
So anyway, my laptop just boots (I think I installed it using Lilo, but I don't remember at this point and don't have it with me), while my computer, when booting from the secondary HD, boots to the Grub loader prompt.
Grub>
Where I can enter a number of commands. I'm guessing (though am not sure) that in order for me to be able to boot, I'll have to establish some sort of config file...however, for the meantime, I can't even get to any sort of prompt.
So will this series of commands that I enter get me started, and from there, what will I have to do to not have to deal with the boot loader screen in the future, unless I want to (i.e. by hitting something during bootup, etc.).
root (hd1,0) [or wherever /boot/grub/stage1 is found...for me should be hd1,0 I think]
setup (hd1)
Will that work? Or is there a better way for me to approach the dual-booting of XP + Linux? Please LMK - I am open to reinstalling redhat entirely, as I don't have anything up yet anyway.
Rob
Grub>
setup (hd1)
Rob
