Koing
Elite Member <br> Super Moderator<br> Health and F
- Oct 11, 2000
- 16,843
- 2
- 0
It will be hard to improve athletical performance (for you that would be to run further) when cutting down food in general. This will DRASTICALLY affect your ability to run properly. I bet back in HS you weren't 'concerned' with eating like you are now and that helped a lot.
Your back pains is an indicator of bad posture.
Do you warm up and stretch BEFORE RUNNING? This is very important also. Jog 400m or so and then stretch yourself.
USE THE SHOES YOUR BRO bought you. GOOD running shoes that SUIT YOUR RUNNING STYLE IS VERY VERY IMPORTANT. I can not stress this enough.
Up it to 2-3x a week. The 2nd or 3rd session you can just run half of it and walk half the rest. BUILD UP TO IT. You may not be a sadist like me and like to break yourself to bits. A lot of people often give up. Build up to it :thumbsup:.
Keep us updated on your efforts and your running partner will drastically improve your ability to run to no end
. I use to run okay but I couldn't be bothered with it. I ran with a partner and we both pushed each other hard as neither of us wanted to give up.
Koing
Koing
